Threads: 52
where can I find an "how to" for mysql integration ?
For example:
I want insert/read some values in a remote database (in the same LAN).
If there is an example it'll be appreciate.
Alberto
KNX Advanced Partner + Tutor
Threads: 31
Look here, make sure you install correct packages as this thread is very old
https://forum.logicmachine.net/showthrea...797#pid797
Threads: 52
17.10.2023, 13:34
(This post was last modified: 17.10.2023, 13:36 by toujour.)
thanks for your reply but I don't find the correct link in that thread...all the links are offline (404).
Can you check it, please ?
Threads: 31
Extra packages are always below the firmware links
https://dl.openrb.com/lm-23-imx6/pkg/
Threads: 52
ok....and the docs about it, please ?
Threads: 52
ok, this for request (it works with luamysql package).
require('luasql.mysql')
env = luasql.mysql()
dbcon = env:connect(DB_NAME, USERNAME, PASSWORD, MYSQL_SERVER_IP, MYSQL_SERVER_PORT)
cursor = dbcon:execute('SELECT * FROM mytable')
while true do
row = cursor:fetch({}, 'a')
if row then
log(row)
break
cursor:close()
dbcon:close()
env:close()
