Threads: 40
Only analog (numeric) and binary values are supported by BACnet swrver.
Threads: 6
(30.06.2022, 13:24)asgeirsb Wrote: Hi! Great script, thanks!
I'm having an issue, trying to export the 250 byte strings for sunrise and sundown and calculated sunrise and sundown, but it won't let me export those objects.
Also I did some adjustment to the script and byte the same times as 3 byte date / time but I still can't export to BACnet. Any reason it won't let me?
Do you need this values in a SE (EBO) system? If yes, i have ported this function to Plain English so you have all values as BACnet datetime objects there..
Threads: 4
(01.07.2022, 05:33)Erwin van der Zwart Wrote: (30.06.2022, 13:24)asgeirsb Wrote: Hi! Great script, thanks!
Actually, yes! Would love that
Threads: 6
01.07.2022, 09:55
(This post was last modified: 01.07.2022, 10:01 by Erwin van der Zwart.)
Here you go (:
Created for EBO 2.0 and higher
Threads: 4
(01.07.2022, 09:55)Erwin van der Zwart Wrote: Here you go (:
Thank you very much!
Threads: 4
Hello again.
Is it possible to transfer time and/or dates through BACnet?
I need to send sunset and sunrise times to an atvise server through bacnet but I am struggeling
Threads: 40
Date/time BACnet type is not supported. A possible workaround is to split hours and minutes into separate numeric objects.
Threads: 84
(13.12.2016, 19:45)Erwin van der Zwart Wrote: Hi Josep,
Make sure this function is inside common functions:
Code: -- sunrise / sunset calculation
function rscalc(latitude, longitude, when)
local pi = math.pi
local doublepi = pi * 2
local rads = pi / 180.0
local TZ = function(when)
local ts = os.time(when)
local utcdate, localdate = os.date('!*t', ts), os.date('*t', ts)
localdate.isdst = false
local diff = os.time(localdate) - os.time(utcdate)
return math.floor(diff / 3600)
local range = function(x)
local a = x / doublepi
local b = doublepi * (a - math.floor(a))
return b < 0 and (doublepi + b) or b
when = when or os.date('*t')
local y2k = { year = 2000, month = 1, day = 1 }
local y2kdays = os.time(when) - os.time(y2k)
y2kdays = math.ceil(y2kdays / 86400)
local meanlongitude = range(280.461 * rads + 0.9856474 * rads * y2kdays)
local meananomaly = range(357.528 * rads + 0.9856003 * rads * y2kdays)
local lambda = range(meanlongitude + 1.915 * rads * math.sin(meananomaly) + rads / 50 * math.sin(2 * meananomaly))
local obliq = 23.439 * rads - y2kdays * rads / 2500000
local alpha = math.atan2(math.cos(obliq) * math.sin(lambda), math.cos(lambda))
local declination = math.asin(math.sin(obliq) * math.sin(lambda))
local LL = meanlongitude - alpha
if meanlongitude < pi then
LL = LL + doublepi
local dfo = pi / 216.45
if latitude < 0 then
dfo = -dfo
local fo = math.min(math.tan(declination + dfo) * math.tan(latitude * rads), 1)
local ha = 12 * math.asin(fo) / pi + 6
local timezone = TZ(when)
local equation = 12 + timezone + 24 * (1 - LL / doublepi) - longitude / 15
local sunrise, sunset = equation - ha, equation + ha
if sunrise > 24 then
sunrise = sunrise - 24
if sunset > 24 then
sunset = sunset - 24
return math.floor(sunrise * 60), math.ceil(sunset * 60)
Then create a resident script with time 60 seconds and add this code:
Code: -- ***** Astronomic clock module Version 1.0 Created by Erwin van der Zwart ***** --
-- ********* Use this script as resident script and run every 60 seconds ******** --
-- ****** This script makes use of rscalc function inside common functions ****** --
-- ******************************** SET PARAMETERS ****************************** --
-- Set output address
adressoutput = '1/1/1' -- 1 bit output for control object
-- Set time shifting addresses
addressshifttimesunrice = '1/1/2' -- 1 or 2 byte signed integer to be able to adjust/offset calculated sunrise time (set min/max on object)
addressshifttimesundown = '1/1/3'-- 1 or 2 byte signed integer to be able to adjust/offset calculated down time (set min/max on object)
-- Set feedback adresses
addresssunrise = '1/1/4' -- 255 byte object for user feedback, shows calculated sunrise time
addresssundown = '1/1/5' -- 255 byte object for user feedback, shows calculated sundown time
addresssunriseshifted = '1/1/6' -- 255 byte object for user feedback, shows with offset calculated sunrise time
addressundownshifted = '1/1/7' -- 255 byte object for user feedback, shows with offset calculatedsundown time
-- Set location coordinates
latitude = 52.52198 --Zwolle Netherlands, Look at 'http://www.mapcoordinates.net/en' for other locations
longitude = 6.08213 --Zwolle Netherlands, Look at 'http://www.mapcoordinates.net/en' for other locations
-- ******************************** END PARAMETERS ****************************** --
-- ********************* DON'T CHANGE ANYTHING UNDER THIS LINE ****************** --
-- Function to calculate switching times based and output value
function astronomic(latitude,longitude,shiftedsunrise,shiftedsundown)
local now = os.date('*t')
local sunrise, sunset = rscalc(latitude, longitude, now) --Zwolle Netherlands, See http://www.mapcoordinates.net/en for other locations
sunriseorg = string.format('%d:%.2d', math.floor(sunrise / 60), sunrise % 60)
sunsetorg = string.format('%d:%.2d', math.floor(sunset / 60), sunset % 60)
sunrisenew = sunrise + shiftedsunrise
sunsetnew = sunset + shiftedsundown
sunrisetime = string.format('%d:%.2d', math.floor(sunrisenew / 60), sunrisenew % 60)
sunsettime = string.format('%d:%.2d', math.floor(sunsetnew / 60), sunsetnew % 60)
local minutes = now.hour * 60 + now.min
nowdark = minutes < sunrisenew or sunsetnew < minutes
local t = {sunricenormal = sunriseorg, sundownnormal = sunsetorg, sunriceshifted = sunrisetime, sundownshifted = sunsettime, output = nowdark}
return (t)
-- Get values for timeshifting
shiftedsunrise = grp.getvalue(addressshifttimesunrice) or 0 -- Make minutes negative to switch earlyer than normal calculated sunrice and positive to switch later than normal calculated sunrice
shiftedsundown = grp.getvalue(addressshifttimesundown) or 0 -- Make minutes negative to switch earlyer than normal calculated sundown and positive to switch later than normal calculated sundown
-- Call function to calculate astroinfo
astroinfo = astronomic(latitude,longitude,shiftedsunrise,shiftedsundown)
-- Set new sunrice time (unshifted)
currentvalue = grp.getvalue(addresssunrise)
if astroinfo.sunricenormal ~= currentvalue then
grp.update(addresssunrise, astroinfo.sunricenormal)
-- Set new sundown time (unshifted)
currentvalue = grp.getvalue(addresssundown)
if astroinfo.sundownnormal ~= currentvalue then
grp.update(addresssundown, astroinfo.sundownnormal)
-- Set new sunrice time (shifted)
currentvalue = grp.getvalue(addresssunriseshifted)
if astroinfo.sunriceshifted ~= currentvalue then
grp.update(addresssunriseshifted, astroinfo.sunriceshifted)
-- Set new sundown time (shifted)
currentvalue = grp.getvalue(addressundownshifted)
if astroinfo.sundownshifted ~= currentvalue then
grp.update(addressundownshifted, astroinfo.sundownshifted)
-- Set output value to output object
currentvalue = grp.getvalue(adressoutput)
if astroinfo.output == true then
if currentvalue == false then
grp.write(adressoutput, true)
if currentvalue == true then
grp.write(adressoutput, false)
If you want to combine it with a scheduler then make a 'and' logic, put the output of this script to input 1, output of the schedular to input 2 and the control object to the output of your 'and' logic.
Hi Erwin,
very easy question.
adressoutput = '7/0/4' -- 1 bit output for control object
It gives day or night?
0 for day and 1 for night?
Threads: 6
I have no idea anymore, this code is so old and not used anymore from the day that schedulers has the option to set on sunrise/sunset.
Given the variable is called “nowdark” i assume it’s true when dark but i strongly advise to use the build-in method on the schedulers..
