Threads: 3
Hello ,
I have a problem with saving changes on mosaic 3.0 . I m on my admin account but I can t save anything . Every widgets works and functions too . What can I do to solve this problem? I tried to restart the device but this doesn't change anything. :/
Threads: 31
Go to LM and create a new object, then pres Sync project data and reboot LM. If this object is no longer there then your SD card has switched to read only mode and it will need a replacement. You can make a copy of this card and restore it on new or backup and fallow this.
https://kb.logicmachine.net/misc/reflash...ng-player/
Threads: 31
Send me your backup via PM. Use wetransfer.com or similar
Threads: 31
The issue above was generated by use of custom images. Use very small images and try to avoid using them as much as possible.
