Full restore
I have a question about backup and restore.
I want to change a LM5 lite to LM5 Reaktor. And I want to do a full copy.
Is there anywhere to copy all Logic Machine? (Not only configuration).
I want to copy all apps: Alexa, Google home, Zigbee, Zigbee module configuration, Mosaic, LM Cloud.... Is it posible?
Just make backup and all settings of the apps will be there. You will need to manually install the apps ftom the store but the settings will be there. LM cloud will ask you if you want to connect to cloud on new device.
(14.12.2023, 09:01)Daniel Wrote: Just make backup and all settings of the apps will be there. You will need to manually install the apps ftom the store but the settings will be there. LM cloud will ask you if you want to connect to cloud on new device.
Ok thanks!
