Bacnet stopped working
Did anyone ever experience that BACnet stopped working?
Everything else works as normal, but the LM5 lite stopped sending and recieving BACnet objects.
Did try reset, powercycle, firmwareupdate, enable/disable BACnet server.
its no longer reachable by YABE
WEB page works normally, KNX objects are updated both ways
After performing factory reset have you tried running BACnet server with a single exported object (without restoring the backup)? Maybe there's some specific configuration in your backup that prevents the server from running.
Try changing bacnet ID, maybe there is a conflict.
