grp.create()
I'm trying to figure out how to generate a series of viritual adresses. example:
room_nr = {name=, datatype=, }
functions =
etc...
I want GA's to be named something like this: "room_nr""function"
i guess I need a for loop, based on room_nr, but how do I separate the different roomnumbers in the table?
It's most likely easy, brain is in weekend mode Smile
Use this as a starting point:
for i = 1, 10 do
  name = 'room ' .. i
  log(name)
What is the best way, when using grp.create, to check if the GA is allready created? I'm thinking of making a dynamic script, so that when I add new GA's and tag them correctly the script will generate new virtual GA's.
You can use grp.find().
Regarding this, and the funcion string.gsub() my pattern is '_PV' but i also have some GA's named '_PV3'. is there any way to make this function to apply only with _PV and not _PV3?
If your string ends with _PV then you can use _PV$ regular expression. See this for more info: https://www.lua.org/manual/5.1/manual.html#5.4.1
(12.02.2024, 08:20)tomnord Wrote: What is the best way, when using grp.create, to check if the GA is allready created? I'm thinking of making a dynamic script, so that when I add new GA's and tag them correctly the script will generate new virtual GA's.
I use function block like this when automatically generating addresses in my programs...
--**********CREATE GROUP ADDRESSES******************
function createga(groupaddress,datatype,name)
  exist = grp.alias(groupaddress)
  if exist == nil then
    address = grp.create({
    datatype = datatype,
    address = groupaddress,
    name = name,
    comment = 'Automatically created object',
    units = '',
    tags = { },
On some systems I use user script where I put all needed group addresses (so they all are on the same file and it's quite easy to change them)..
User script (HEATING_config):
Main_GA = '33'
group_address_for_frontend_update = '/0/0'        --If any modifications on values or chart must be updated, this variable is used.
group_address_for_backend_update = '/0/1'        --If any modifications on values or data file must be updated, this variable is used.
Scheduled/Resident/Event script:
require('user.HEATING_config')
createga( Main_GA .. group_address_for_backend_update, dt.bool,'HEATING - Update backend')
createga( Main_GA .. group_address_for_frontend_update, dt.bool,'HEATING - Update frontend')
--DO SOMETHING
Hope this helps...
Thanks guys. I'll do some testing
Hi I have a function in a script for creating the necessarily groupadresses. But in this script it´s not creating the adresses, can I ask if someone can see what can be the issue?
-- Skapa nödvändiga gruppadresser
local function skapaGruppadresser()
    local maxZoner = 25  -- Antagande att det finns max 25 zoner
    for i = 100, 121 do
        -- Adresser och namn för zonerna
        local varaktighetAddress = '40/2/' .. i
        local dagligVaraktighetAddress = '40/4/' .. i
        local varaktighetName = 'Varaktighet Zon ' .. i
        local dagligVaraktighetName = 'Daglig Varaktighet Zon ' .. i
        -- Skapa adress för varaktighet om den inte redan finns
        if not grp.find(varaktighetAddress) then
            grp.create({datatype = 'dt.text', address = varaktighetAddress, name = varaktighetName})
        -- Skapa adress för daglig varaktighet om den inte redan finns
        if not grp.find(dagligVaraktighetAddress) then
            grp.create({datatype = 'dt.text', address = dagligVaraktighetAddress, name = dagligVaraktighetName})
    -- Skapa återställningsflagga om den inte redan finns
    local resetAddress = '40/3/0'
    if not grp.find(resetAddress) then
        grp.create({datatype = 'dt.bool', address = resetAddress, name = 'Återställningsflagga'})
datatype field should be either dt.text (without quotes) or 'text'
(13.04.2024, 08:44)admin Wrote: datatype field should be either dt.text (without quotes) or 'text'
Thanks! That solved it... Big Grin
