Threads: 103
Hi ,
I need to add to the scene sequence or to remove from the scene sequence via script like this.
value = event.getvalue()
if value == true then
-- add object '1/1/1' to scene 'homeenter'
-- remove object '1/1/1' to scene 'homeenter'
Thx,
Threads: 31
Might be simpler to create two scenes with and without the object and just enable/disable them based on the condition above.
Another solution is to use a virtual object with AND gate via an event script:
Code: value = event.getvalue()
gate = '1/1/1'
output = '1/1/2'
if grp.getvalue(gate) then
grp.write(output, value)
Threads: 103
08.03.2024, 09:29
(This post was last modified: 08.03.2024, 09:49 by savaskorkmaz.)
Unfortunately, neither solution works for me. My goal is for the customer to change the scenarios 100% by himself, on a screen.
I have a design like the attached picture.
Theoretically, I can create a virtual output poinst and virtual selection points for all group addresses and gate them with the event script. However, we are doing this demo not for our own project, but for our dealers, and creating hundreds of additional points and creating hundreds of additional scripts is not a sustainable business and partners eventually mix up the scripts and the job becomes impossible.
For this reason, my only way is to add and remove objects with a simple script. I need your help on this matter.
Note : i can' upload picture to the post.
here is the link of screen.
https://ibb.co/qxStbzC
Threads: 31
Do you know this?
Threads: 103
08.03.2024, 09:34
(This post was last modified: 08.03.2024, 09:39 by savaskorkmaz.)
I need a solution for visualation page. Not for mosaic beta
(08.03.2024, 09:29)savaskorkmaz Wrote: Unfortunately, neither solution works for me. My goal is for the customer to change the scenarios 100% by himself, on a screen.
Add to Common functions:
Code: function getscenebyname(name)
local id = db:getone('SELECT id FROM scenes WHERE name=?', name)
assert(id, 'scene not found: ' .. name)
return id
function getsequenceid(sceneid, object)
local query = 'SELECT id FROM scene_sequence WHERE scene=? AND object=?'
return db:getone(query, sceneid, object)
function getdata(name, addr)
local scene = getscenebyname(name)
local object = buslib.encodega(addr)
local sequenceid = getsequenceid(scene, object)
return scene, object, sequenceid
function addtoscene(name, addr)
local scene, object, sequenceid = getdata(name, addr)
local res, err
if sequenceid then
err = 'object already added'
res, err = require('webrequest')('scenes', 'sequence-save', {
data = {
scene = scene,
object = object,
bus_write = true,
return res, err
function removefromscene(name, addr)
local res, err
if sequenceid then
res, err = require('webrequest')('scenes', 'sequence-delete', {
data = {
id = sequenceid
if not err then
res = true
err = 'object not found in scene'
return res, err
Usage example:
Code: scenename = 'test'
address = '0/0/1'
res, err = addtoscene(scenename, address)
log(res, err)
res, err = removefromscene(scenename, address)
log(res, err)
Scene name must be unique. Each object can be in the scene only once.
Threads: 103
Worked wery well. Thx a lot.
