MQTT CLIENT AutoRefreshing
Ciao,
I was willing to find a way by whitch MQTT client script would autorefresh its configuration, so I made some changes to the MQTT script available in
https://kb.logicmachine.net/integration/mqtt-client/
My changes works in this way:
the script use the object name as topic and define a local table to convert values in case of need
I use the object comment field to input a short lua table definition that will be parsed by the script.
comments syntax is (starting at col 1):
config = { 'topic', 'conversion method' }
 conversion methos should be one key in the CONVERTER table
this is my code for handler script:
local BROKERADDRESS = '127.0.0.1' local BROKERUSER    = 'userid'    -- use nil if no user/pass needed local BROKERPASSWD  = 'password'  -- use nil if no user/pass needed -- VALUE CONVERSION TABLE local CONVERTER = {    ['toBoolString']    =    function(input_state)        -- true >> 'true' / false >> 'false'                           return tostring(input_state)                       end   ,['BooltoString']    = function(input_state)            -- true >> 'ON'   / false >> 'OFF'                             return (input_state and "ON" or "OFF")                       end   ,['StringtoBool'] = function(input_state)                           return (input_state:upper() =='ON' or input_state:upper() == 'TRUE' and true or false)                         end   ,['BooltoNum']      = function(input_state)        -- true >> 1      / false >> 0                           return (input_state and 1 or 0)                         end   ,['NumtoBool']         = function(input_state)            -- 1 >> true            / 0 >> false                           return toboolean(input_state)                         end   ,['HextoDec']     = function(input_state)                                        -- #FFFFFF                / 16777215                                                 return tonumber(input_state:gsub('#',''), 16)                                           end   ,['DectoHex']     = function(input_state)                                        -- 16777215       / #FFFFFF                                                 return string.format('#%X',input_state):upper()                                           end   ,['toNumber']     = function(input_state)                                        -- '1'                        / 1                                             return tonumber(input_state)                                             end } function converter(input_state, conversion_request)   if CONVERTER[conversion_request] then     return CONVERTER[conversion_request](input_state)   else     return input_state   end end if not broker then   broker = BROKERADDRESS     username,password = BROKERUSER, BROKERPASSWD     -- topic to object map   mqtt_to_object = {}   -- optional topic value conversion function   mqtt_to_object_conv = {}   -- object to topic map   object_to_mqtt = {}   objs = grp.tag('mqtt-control')   for _, obj in ipairs(objs) do     if string.find(obj.comment,"config") == 1 then       assert(loadstring(obj.comment))()         object_to_mqtt[ obj.address ] = {           topic   = config[1],         convert =  config[2]       }     end   end   objs = grp.tag('mqtt-status')   for _, obj in ipairs(objs) do     if string.find(obj.comment,"config") == 1 then       assert(loadstring(obj.comment))()         mqtt_to_object[ config[1] ] = {           address = obj.address,         convert =  config[2]       }     end   end   datatypes = {}   grp.sender = 'mq'   require('socket')   for addr, _ in pairs(object_to_mqtt) do     local obj = grp.find(addr)     if obj then       datatypes[ addr ] = obj.datatype     end   end   mclient = require('mosquitto').new()     if username and password then     mclient:login_set(username,password)   end     mclient.ON_CONNECT = function(res, ...)     log('mqtt connect status', res, ...)     if res then       for topic, _ in pairs(mqtt_to_object) do         mclient:subscribe(topic)       end     else       mclient:disconnect()     end   end   mclient.ON_MESSAGE = function(mid, topic, payload)     if mqtt_to_object[ topic ] then         payload =  converter(payload,mqtt_to_object[ topic ].convert)             grp.write(mqtt_to_object[ topic ].address, payload)     end   end   mclient.ON_DISCONNECT = function(...)     log('mqtt disconnect', ...)     mclientfd = nil   end   function mconnect()     local fd     mclient:connect(broker)     fd = mclient:socket()     -- fd ref is valid     if fd then       mclientfd = fd     end   end   mconnect()   function publishvalue(event)     -- message from us or client is not connected     if (event.sender == 'mq' or not mclientfd ) or not object_to_mqtt[ event.dst ] then       return     end     local addr = event.dst     local dpt = datatypes[ addr ]     local topic = object_to_mqtt[ addr ].topic     -- unknown object     if not dpt or not topic then       return     end     local value = busdatatype.decode(event.datahex, dpt)     log(value)     if value ~= nil then             if object_to_mqtt[ addr ].convert then value =converter(value, object_to_mqtt[ addr ].convert) end       mclient:publish(topic, tostring(value))     end   end   lbclient = require('localbus').new(1)   lbclient:sethandler('groupwrite', publishvalue)   lbclientfd = socket.fdmaskset(lbclient:getfd(), 'r')   -- run timer every 5 seconds   timer = require('timerfd').new(5)   timerfd = socket.fdmaskset(timer:getfd(), 'r') end -- mqtt connected if mclientfd then   mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')   res, lbclientstat, timerstat, mclientstat =       socket.selectfds(10, lbclientfd, timerfd, mclientfdset) -- mqtt not connected else   res, lbclientstat, timerstat =     socket.selectfds(10, lbclientfd, timerfd) end if mclientfd and mclientstat then   if socket.fdmaskread(mclientstat) then     mclient:loop_read()   end   if socket.fdmaskwrite(mclientstat) then     mclient:loop_write()   end end if lbclientstat then   lbclient:step() end if timerstat then   -- clear armed timer   timer:read()   if mclientfd then     mclient:loop_misc()   else     mconnect()   end end
this script shuld be a resident at 0 sec pause and named LMIta_MQTT_Handler
Next, as a scheduled (I use every 5 mins, but you can choose yours) the following code
local STORAGE_FILE_IN    = 'lmita_mqtt_in' local STORAGE_FILE_OUT   = 'lmita_mqtt_out' local SCRIPT_HANDLE_NAME = 'LMIta_MQTT_Handler'   -- handler script name! local TABSTORE_IN  = storage.get(STORAGE_FILE_IN, nil) local TABSTORE_OUT = storage.get(STORAGE_FILE_OUT, nil) local TABLOCAL_IN  = {} local TABLOCAL_OUT = {} local J = require('json') local function compareTables(tableA, tableB)   local compareResult = true                            -- false > not equals / true > equals     -- verifying input parameters   if type(tableA) ~= 'table' or type(tableB) ~= 'table' then return false end     -- start Verifying tableA is in tableB   for index, value in pairs(tableA) do     if J.encode(tableB[index]) ~= J.encode(value) then           compareResult = false           break     end   end   -- start Verifying tableB is in tableA   if compareResult == true then     for index, value in pairs(tableB) do       if J.encode(tableA[index]) ~= J.encode(value) then           compareResult = false           break       end     end   end   return compareResult  end function buildLocal()   objs = grp.tag('mqtt-control')   for _, obj in ipairs(objs) do     if string.find(obj.comment,"config") == 1 then       assert(loadstring(obj.comment))()         TABLOCAL_OUT[ obj.address ] = {           topic   = config[1],         convert =  config[2]       }     end   end   objs = grp.tag('mqtt-status')   for _, obj in ipairs(objs) do     if string.find(obj.comment,"config") == 1 then       assert(loadstring(obj.comment))()         TABLOCAL_IN[ config[1] ] = {           address = obj.address,         convert =  config[2]       }     end   end end buildLocal() if not compareTables(TABSTORE_IN, TABLOCAL_IN) or not compareTables(TABSTORE_OUT, TABLOCAL_OUT) then   storage.set(STORAGE_FILE_IN, TABLOCAL_IN)   storage.set(STORAGE_FILE_OUT, TABLOCAL_OUT)   log("Config changed, restarting script")   script.disable(SCRIPT_HANDLE_NAME)   os.sleep(1)   script.enable(SCRIPT_HANDLE_NAME) end
this script with check che tag tables and compare it to a copy stored, if it does not match (different keys or content) then it will save into a storage the new configuration and restart the handler script
I've tested it with several oblects and different conversions and run quite good
It could has still some bugs... but the main code is this...
hope this could help you
Ciao
M
