Reactor modem problem
HI
I have a problem with the LM5 Reactor GM KNX, already updated to the latest firmware version, it doesn't get the IP from the cellular network, I tried the SIM on a phone and the card works, as usual no GW configured.
What could it depend on?
A thousand thanks
1. Check that the modem is detected when the system starts in System config > Status > System log.
2. Run this script and post what you get in Logs:
tty1 = '/dev/ttyACM3'
tty2 = '/dev/ttyUSB2'
if io.exists(tty1) then
  tty = tty1
elseif io.exists(tty2) then
  tty = tty2
  log('port not found')
  return
port = require('serial').open(tty)
if not port then
  log('cannot open port')
  return
function readstatus()
  local data, res, simok, network
  port:flush()
  port:write('AT+CSQ\r\n')
  data = port:read(1000, 1)
  if data then
    res = data:match('+CSQ: (%d+)')
    res = tonumber(res)
    if res then
      log('Signal: ' .. tostring(res))
      log('Signal: no response')
    log('Signal: no data from port')
  port:flush()
  port:write('AT+CPIN?\r\n')
  data = port:read(1000, 1) or ''
  if data:find('CME ERROR') then
    log('SIM: not found')
  elseif data:find('+CPIN: READY') then
    log('SIM: OK')
    simok = true
    log('SIM: unknown')
  port:flush()
  port:write('AT+COPS?\r\n')
  if data then
    res = data:match('+COPS: %d+,%d+,"(.*)",%d+')
    if res then
      log('Network: ' .. tostring(res))
      network = res
      log('Network: no info')
    log('Network: no data from port')
  return simok and network
for i = 1, 20 do
  if readstatus() then
    break
(19.04.2024, 07:55)admin Wrote: 1. Check that the modem is detected when the system starts in System config > Status > System log.
  tty = tty1
  tty = tty2
  return
if not port then
  return
  port:flush()
  if data then
    res = tonumber(res)
    if res then
  port:flush()
    log('SIM: OK')
    simok = true
    log('SIM: unknown')
  port:flush()
  if data then
    if res then
      network = res
for i = 1, 20 do
    break
OK in the log i see error network no info and SIM not found signal 13, but in the phone the SIM works.
Why ?
Maybe it's a hardware fault. Is it a new device or an older one that worked before?
(19.04.2024, 08:17)admin Wrote: Maybe it's a hardware fault. Is it a new device or an older one that worked before?
Is a device that we had at home never used and that we sent to you to install the LTE modem instead of the GSM and now I had to use it on a system.
now IP is released, SMS also work from mobile but Zerotier doesn't see it when I use the integrated MODEM.
when i try to see if Zerotier get IP have this message
