Connector Bridge RS485 Interface
Hello, I have a Connector Bridge RS485 Interface device. Can you send the script how to send such commands through modbus.
I am trying the common function:
function blind(command)
require('serial')
port = serial.open('/dev/RS485-1', { baudrate = 9600, parity = 'none', databits = 8, stopbits = 1 })
port:flush()
port:write(command)
port:close()
Example event script:
blind('!000V?;')
I am attaching the command of the device
Thank you
.pdf   Connector_Bridge_RS485_Interface.pdf (Size: 288.66 KB / Downloads: 21)
Use this script to send a command and receive a reply from the bridge. Make sure that only a single script instance is running at any time. Serial port cannot be shared between multiple concurrent scripts.
require('serial') port = serial.open('/dev/RS485-1', { baudrate = 9600 }) function readreply()   local line = {}   while true do     local char, err = port:read(1, 5)     if char == nil then       return nil, err     elseif char == ';' then       break     else       line[ #line + 1 ] = char     end   end   return table.concat(line) end command = '!000V?;' port:write(command) res, err = readreply() log(res, err)
