Threads: 9
Hello sir one of the client has taken us from LM5 Lp2 and he installed the streaming player firmware in it .
after that it is stopped working I tried to hardware reset it but it does not work .
sir could you pls provide dome suggestion and help
Threads: 9
hello sir I tried it but it is showing this error
Try a different microSD card.
Threads: 9
Sir its Showing the same error in different new sd card
Then try a different SD card reader or use a different PC.
Threads: 9
hello sir i am resetting lm ambient and using new sd card it is showing this error
Are you using SD to micro SD adapter? If so you need to flip the switch on the side to disable write protection.
