Threads: 54
All of the objects have disappeared from the LM5. When I try to create a new object, it says the address is already in use. The LM5 is running the latest firmware, and I have tried accessing it with different browsers.
Threads: 31
Make a backup and send me to PM
Threads: 31
You have 6628 objects, this is way too much for single device. It will work but with the symptoms as you see. Loading will take a while. The best way forward is to remove not needed objects and also add filter table to not update not needed objects.
Threads: 0
I have a problem after upgrading my LM5 Lite to firmware lm5m3-20240426 no objects are shown in the object list.
Also all sequences in scenes are empty.
It looks like everything is still in the database...
Any ideas?
Threads: 31
Did you try restoring a backup? I'm guessing you did a backup before firmware upgrade?
Threads: 0
Yes I tried to restore the backup but it is still blank
Threads: 31
send me your backup to PM, will check it on another LM
Threads: 31
Your backup is fine, I can see everything. Try installing the firmware again.
Threads: 0
Re-installed firmware, but still blank
Threads: 31
Did you clear browser cache?
If this wont help they you should re-flash the SD card.
https://kb.logicmachine.net/misc/reflash...ng-player/
Threads: 0
I tried a factory reset, thought I could try to restore the backup.
Now I can no longer log in... admin/admin does not work, not the old pwd either.
I will try to re-flash the SD card next.
Threads: 0
Double factory reset (2 x 10 seconds)
Restore backup -> Worked!!
Thank you for your support :-)
