23.08.2024, 12:05
I'm using websocket library to connect to Unifi Access device and receive status info from it, but the problem i have is once i receive status update, the message is too long to even fit into the logs line and the whole script crashes without an error and i need to restart the script for it to start receiving status updates again. The websocket library is a little bit too complicated for me to understand what I'm looking for to fix this.
Maybe someone else has had a similar issue and knows how to fix this?
I attached the event script I'm using for connection and websocket library file.
Thank you in advance!
