(30.09.2024, 07:43)admin Wrote: What exactly do you want to control via API?
Thanks for the feedback.
I want to have it detect me and send information via the API to trigger contexts that are specific to me. Or send a welcome home notification to the ceiling speaker.
Run this script as resident. Change host variable to your camera IP and auth variable to access credentials in username:password format. Make sure that Basic auth mode (not digest) is set on your camera. Then post what you get in LM Logs when running this script.
local json = require('json')
local socket = require('socket')
local mime = require('mime')
local host = '192.168.1.1'
local auth = 'user:password'
local sock = socket.tcp()
sock:settimeout(15)
local res, err = sock:connect(host, 80)
if not res then
sock:close()
log('connect failed', err)
os.sleep(5)
return
local function init()
local crlf = '\r\n'
sock:send(
'GET /FR/events/live/json?heartbeat=10 HTTP/1.1' .. crlf ..
'Host: ' .. host .. crlf ..
'Authorization: Basic ' .. mime.b64(auth) .. crlf .. crlf
local function parse(resp)
resp = json.pdecode(resp)
log(resp)
init()
local pat, len = nil, nil
while true do
res, err = sock:receive(pat)
log('rx', pat, res, err)
if err then
sock:close()
log('receive error', err)
break
if type(pat) == 'number' then
pcall(parse, res)
pat, len = nil, nil
elseif #res == 0 then
pat = len
elseif not len then
len = res:match('Content%-Length: (%d+)')
len = tonumber(len)
(02.10.2024, 11:52)admin Wrote: Run this script as resident. Change host variable to your camera IP and auth variable to access credentials in username:password format. Make sure that Basic auth mode (not digest) is set on your camera. Then post what you get in LM Logs when running this script.
sock:settimeout(15)
if not res then
sock:close()
os.sleep(5)
return
local crlf = '\r\n'
sock:send(
log(resp)
init()
while true do
if err then
sock:close()
break
pcall(parse, res)
pat, len = nil, nil
pat = len
elseif not len then
len = tonumber(len)
Thanks for the reply.
I am sending the log again as attached file.
Please help me.
(07.10.2024, 06:33)admin Wrote: You need to trigger a face detection event and check if it's logged. You can disable the log call on line 40 to filter out debug info:
-- log('rx', pat, res, err)
I send the information back, admin please check it for me
I see LM has connected and recognized
Please give me the command to control
Thank you very much
Replace parse function in the script with the following code. The script will send ON to 1/1/1 each time the camera detects you.
if resp.type == 'person' then
if resp.name == 'luan thanh' then
gpr.write('1/1/1', true)
(10.10.2024, 13:04)admin Wrote: Replace parse function in the script with the following code. The script will send ON to 1/1/1 each time the camera detects you.
I checked, tested everything works perfectly.
Thank you very much
