Thanks for testing.
Bugs:
1. Provide steps to reproduce and/or backup from your controller.
Improvements:
1. We might add this later.
2. Using Ctrl/Shift + click should be enough for most cases.
3. This stays as is it, automatic saving is a deliberate design choice.
Threads: 2
23.10.2024, 10:02
(This post was last modified: 23.10.2024, 10:02 by forsterm.)
2. Ok, I find that selecting multiple objects with the mouse is firstly faster than having to click on each one individually and secondly it is an intuitive function, so I believe that many users assume that they can select multiple objects with the mouse.
Is it too complex to programme this functionality, or just a "design" decision?
3. Would it then be possible to insert an "undo" button?
Resizing issue is caused by a missing function in the firmware that you use.
