Threads: 2
hello,
since firmware 20160927, i have a lot of script and visualisation. I want to raz all but :
- when i set reset factory... nothing is erased
- when i restore my backup nothing doing... my trends, names of objects... are no loaded
i'll probably make a mistake...
You need to install recovery firmware to the new MicroSD card from your PC before replacing it in LM.
Threads: 8
The SD card is internal on the board, you have to open the device to reach it.
Reset button to factory settings, you have to press it 10 seconds (you see the LED red), release and press direct again for 10 sec (you see LED red flash), release again and press direct again and press 10 seconds. The device will reboot after a small period, just be patience...
However as admin say's SD is in read only mode, the reset will probably not work...
Threads: 2
I have done the recovery reset with new sd card, then flashing firmware...
that's OK for few Hours... then LM reactor become antother time not joignable. IP no responding
