easy way to search trough scenes?
Is there an easy way to search for a GA in all scenes?
I use "print script listings" to search trough all the scripts for a specific text a lot - and I would love to have a similar "dump" of all the scenes.
Create scenes.lp file and upload it via FTP to user directory using apps login. FTP can be enabled in System config > Services.
Then you can access it via http://LM_IP/user/scenes.lp
<!DOCTYPE html> <html lang="en"> <head> <meta charset="UTF-8"> <meta name="viewport" content="width=device-width, initial-scale=1.0"> <link rel="stylesheet" href="/apps/css/bootstrap.css.gz"> <style>body { padding: 20px 20px 0 20px; }</style> <title>Scenes</title> </head> <body> <table class="table"> <? require('apps') function isdefined(val)   return toboolean(val) end function numtoga(addr)   return isdefined(addr) and buslib.decodega(addr) or '' end scenes = db:getall([[   SELECT s.id, s.name, s.trig_object, s.trig_value, o.name AS trig_name   FROM scenes s   LEFT JOIN objects o ON s.trig_object=o.id   ORDER BY s.name ]]) for _, scene in ipairs(scenes) do ?>   <tr class="bg-primary">     <td colspan="3"><b><?=escape(scene.name)?></b></td>   </tr> <?   if isdefined(scene.trig_object) then ?>   <tr class="bg-info">     <td><?=numtoga(scene.trig_object)?></td>     <td><?=escape(scene.trig_name or '')?></td>     <td><?=escape(scene.trig_value)?></td>   </tr> <?   end   sequence = db:getall([[     SELECT s.object, s.value, o.name     FROM scene_sequence s     LEFT JOIN objects o ON s.object=o.id     WHERE s.scene=?     ORDER BY s.sortorder   ]], scene.id)   for _, item in ipairs(sequence) do   ?>     <tr>       <td><?=numtoga(item.object)?></td>       <td><?=escape(item.name or '')?></td>       <td><?=escape(item.value)?></td>     </tr>   <?   end end ?> </table> </body> </html>
Super - it works perfect.
Thanks for your fantastic support (as always).
Hi Admin
is it possible to do the same/similar for the Homekit-app?
Try this:
<!DOCTYPE html> <html lang="en"> <head> <meta charset="UTF-8"> <meta name="viewport" content="width=device-width, initial-scale=1.0"> <link rel="stylesheet" href="/apps/css/bootstrap.css.gz"> <style>body { padding: 20px 20px 0 20px; }</style> <title>Homekit</title> </head> <body> <table class="table"> <? require('apps') devices = storage.exec('hgetall', 'app:homekit:devices') for _, device in pairs(devices) do   props = json.pdecode(device) or {} ?>   <tr class="bg-primary">     <td colspan="2"><b><?=escape(props.name)?></b> (<?=escape(props.type)?>)</td>   </tr> <?   for key, val in pairs(props) do     if (key:find('_status') or key:find('_control')) and type(val) == 'string' and #val > 0 then     ?>       <tr>         <td><?=escape(key)?></td>         <td><?=escape(val)?></td>       </tr>     <?     end   end end ?> </table> </body> </html>
(21.02.2025, 09:53)admin Wrote: Try this:
Works perfectly  :-)
Thanks again (and again and ...)
