HTML Code to get the data-object an data-object-name
Is there e way to get the data-object (for example group adress 1/1/6) and the data-object-name once a button is pushed?
I have a user/customapp.lp with html code and want to extract this data of once a button is pushed (so there will be multiple on the visu).
Kind Regards
Giel
picture: https://ibb.co/ccRM9rQK
Add an Additional class (my-element) to the element then add this to Custom JavaScript.
$(function(){   $('.my-element').click(function() {     var data = this.dataset;     var message = {         object: data.object,       objectName: data.objectName,     }          window.parent.postMessage(message);   }); });
In .lp document which includes the visualization via iframe use this code to get the message:
window.addEventListener('message', function(event) {   console.log('event data', event.data) }, false);
Morning everybody
I'm a beginner on wiser for knx. I want to read data sent from smartmeter and then send instructions to an actuator depending on what i received from smartmeter
(13.02.2025, 09:02)Fistel Wrote: Morning everybody
Create a new thread and describe with more details what meter is it and what interface it has.
This topic is about something totally different.
(13.02.2025, 08:55)admin Wrote: Add an Additional class (my-element) to the element then add this to Custom JavaScript.
Hello, it works thanks for the help!
