Send email alert when group has been on for 5 minutes
I have a sensor on a garage door which monitors whether the door is open (value of 255) or closed (value of 0)
I'd like to script an email alert which gets triggered if the door has been left open for more than 5 minutes.
Many thanks in advance
Kind Regards
James
Use Event script with "Execution mode" set to "Last instance":
value = event.getvalue() if value == 255 then   os.sleep(5 * 60)   -- send alert end
Where does one set the Execution Mode to Last Instance (I'm on a CBUS SHAC so perhaps don't have this option)?
Would the following work on the SHAC - event script name is "'Garage Door Open Too Long Notification" - script gets killed if the sensor returns to value 0
if (event.getvalue() == 255) then   log('The garage door has been opened.')   os.sleep(5*60)   log('The garage door has been left open for 5 minutes.')   end   if (event.getvalue() == 0) then   log('The garage door is closed.')   item = script.get('Garage Door Open Too Long Notification')   script.kill(item.id) end
... hmm the script.kill above doesn't seem to work as intended. The first instance of the script keeps running, when the script gets called again on door close.
Any ideas how to modify the above to stop the first instance of the script which is sleeping for 5*60 seconds??
see this:
https://forum.logicmachine.net/showthrea...4#pid18564
Thanks Daniel - that approach works.
