sheduler unreliable
Lights are switching based upon the sheduler.
Now and then the lights are not swithed.  This only happens once each year, but now the frequency has increased to weekly.
Usually it works after bakc after a day, so it is really only one missed communication.
The object log shows that the sheduler did not send the on-off message.
This happens very infrequent.
The unit has been restarted and has the SW 2,8,8.
What could be the issue
It is only the sheduler that is related to sunset sundown that shows the problem / all the other shedulers related to a fixed timing are working well
The sunset and sundown  and current times are logged and this is fine
Any errors in error log?
cannot open /tmp/scripting/47.lua: No such file or directory
An switch on-off timer is also not functioning anymore
The timers that give the problem are marked in red in the visual
.gz   Scripting-CERCON001-2025.05.02-12.16.tar.gz (Size: 4.91 KB / Downloads: 1)
How old is this device?
Check system uptime - System- Status-System status
(02.05.2025, 11:08)Daniel Wrote: How old is this device?
Did you restart the system recently?
Yes, I guess I restarted it a few times in the past weeks -
After a restart all worked well for a certain moment. (1-2..7 days)
The system was restarted 1h and 42 minutes ago. What does the Alert tab says.
Alert tabs only contains System start
meanwhile FM3.0 has been installed. The issue stays on the delay timer. it does not switch off as indicated by the delay setting
In general what you do there is very bad design, having so long delay on event action is not recommended. You should use this instead.
https://kb.logicmachine.net/scripting/on...lay-timer/
