Threads: 28
Hard to say, On/off should work but feedback and energy part depend of vimar implementation.
Threads: 14
What I actually need to know is if it would create a mesh network in order to widen the range. I know every ZigBee device who wired is supposed to work like that but in the past I have tried with a few smart plugs and I could not get the mesh network to work on LM
Threads: 28
Every mains powered device should have router function but you will only find it out once pairing the device. This is nothing to do with LM, Zigbee network does it on its own.
Threads: 28
The % in the app next to device is signal between coordinator(LM) to end device. Use Network map to check signal strength between each device.
Threads: 14
ok I will check again, although I am pretty sure it did not change. Can you just confirm me that I am supposed to se some thing like this in the network map:
gateway-plug-smart valve or is it correct to se every device connected to the gateway
Threads: 28
Threads: 28
No, We have seen some smartplugs to not support router function. It is up to manufacture of this device.
Threads: 14
can you give me any suggestion on which smart plug to buy?
or anything possibly cheap that I can use as a ZigBee router?
Threads: 28
All SE mains powered devices works as a router, Philips hue lights, Ikea bulbs.
