24.09.2018, 19:27
(This post was last modified: 24.09.2018, 19:37 by Erwin van der Zwart.)
Only with pushover..
Alert Manager
24.09.2018, 19:27
Only with pushover.. BR, Erwin
25.09.2018, 07:23
(24.09.2018, 16:36)domotiqa Wrote: Great job !! https://forum.logicmachine.net/showthrea...19#pid6419
26.09.2018, 07:25
I guess the cloud is only for LM device, not for SL and HL
26.09.2018, 07:29
02.10.2018, 15:39
Hey Erwin,
Is there any way to change the color settings of the alert app? Bij Custom CSS? Dennis
02.10.2018, 16:11
No, none of the apps can be changed by custom css. BR, Erwin
16.07.2019, 18:06
(07.06.2017, 18:09)Erwin van der Zwart Wrote: Hi, Hi, I trie create a iframe with URL: /apps/data/alerts/ When I access internally everything works fine. But when I access by cloud I have the error: Not Found (#404) Page not found. The above error occurred while the Web server was processing your request. Please contact us if you think this is a server error. Thank you. Best regards,
17.07.2019, 07:19
I had a problem.
I created the backup on my test server. Then go to customer building (no internet). I could'nt download AlertManager on the HL... the module is not in the backup !
17.07.2019, 07:46
Install it via file
https://we.tl/b-yInxytfwsP
17.07.2019, 13:18
(17.07.2019, 07:46)Daniel. Wrote: Install it via filethank you
01.10.2019, 04:59
Simple question on the alert() function.
Is there otion inside like alert( msg , option) I try to log in the alert manager event from Alarm system activation/desactivation (without sound and maybe different color because not very important). And for more important alarm, keeping the sound regards
01.10.2019, 10:02
No, the command alert is only adding a entry in the alert tab, and that's all the LUA script does. The alert manager receives the content of this alert tab including timestamps over a websocket (and has a polling fallback when the websocket is disconnected), and whenever there is a timestamp that is newer then the last acknowledged timestamp (that is stored in the storage after acknowledge) the audio is started. There is no option to set additional parameters by default. BR, Erwin
06.12.2019, 13:31
(17.07.2019, 07:46)Daniel. Wrote: Install it via fileHello Daniel, I hope you are well, is it possible that you will upload the alert manager app file again? I tried but it was already deleted. Regards.
06.12.2019, 13:33
25.02.2020, 17:52
Hello Daniel,
Is it possible that you will upload the alert manager app file again? I tried but it was already too late)) Regards)))
25.02.2020, 18:07
You can download it direct in your controller from the appstore, no file needed (: BR, Erwin
25.02.2020, 18:54
27.02.2020, 16:37
30.03.2020, 09:06
(25.02.2020, 18:07)Erwin van der Zwart Wrote: Hi, Normally, yes. But the problem is that in many cases the LM/SL is installed in closed technical network, and the LM/SL have no Internet access. It would therefore be good to have the possibility to download the different apps from somewhere.
There are 10 kinds of people in the world; those who can read binary and those who don't
« Next Oldest | Next Newest »
