Script to reboot
I have Zigbee products and I don't know why they disconnect from time to time.
When I restart the controller the products reconnect.
Is there a script to restart the controller automatically at a certain time?
Thx
Which gateway are you using - USB or RS232? Do you have any errors in ZigBee app logs and LM error logs?
(Yesterday, 13:13)admin Wrote: Which gateway are you using - USB or RS232? Do you have any errors in ZigBee app logs and LM error logs?
i use USB dongle and i don't see any error
RS232 is recommended for stability reasons.
Check if USB has been disconnected in System config > System > System log. Logs in the ZigBee app should also show that the app was restarted due to communication timeout.
(10 hours ago)admin Wrote: RS232 is recommended for stability reasons.
I'll get the logs next time I go on site
