Denon Home theater
Dear Admin,
I would like to control music playback (play/pause/stop/mute/select playlist/select track, etc.) from the Logic Machine visualization interface to modern DENON speakers and amplifiers. Is this possible? And if so, how can I set it up to achieve this functionality?
Thank you.
Check this example: https://kb.logicmachine.net/integration/denon/
It's rather old so it might not be compatible with newer Denon hardware. You might need to enable telnet protocol in Denon configuration.
This version is too outdated compared to current Denon AVR devices. Do you have any other suggestions?
Current Denon devices use the HEOS app to control music playback. Is there a way to control them similarly using LogicMachine via the HEOS API?
See this: https://forum.logicmachine.net/showthread.php?tid=190
