LM 5 power supply
How much is LM5 sensitive for correct voltage of main power supply?
Can I simply use 30V DC available in KNX cable (white and yellow pair)? Or is it definetely out of the allowed tolerance?
Thank you
Hi Thomas,
the newest line of LM5 (LM5-Lite, LM5-DW1/PMU/RIO) supports up to 30V DC. Initial LM5 supported up to 24V DC. Please send in PM serial nr. of your device, I will tell exactly then.
The serial is LM53V14170202
The device is LM5Lp
30V DC is fine in this case.
Thank you it works
Same question ... does my LM supports 30V?
- Serial: LM5M3V15A01705027
- Type: LM5p-RD
Thanks in advance.
all LM5-type devices are based on LM5L as main-board + specific extension is added.
So, yes, LM5p-RD also supports 30V DC powering.
