Internal DALI gateway not working
After the last update to v20250813, I noticed that the Internal DALI gateway is not working.
Any suggestions on how to troubleshoot that?
Which LM do you have?
(01.09.2025, 18:20)Daniel Wrote: Which LM do you have?
LM5p2-KCD
We tested it on this LM and it works fine, maybe you installed wrong firmware?
(02.09.2025, 13:33)Daniel Wrote: We tested it on this LM and it works fine, maybe you installed wrong firmware?
If I am not mistaken, I installed the correct one.
This is wrong, you need LM5 Lite + Ext (4 or 6 DIN units)
I messed it with my old LM. Is it ok to install the correct version now?
yes
(04.09.2025, 14:08)Daniel Wrote: yes
Daniel, I just installed the correct version and everything is back in order.
I am not sure how I ended in this mistake, but I suspect something,
that I suggest you to investigate.
Usually, when I have to update, I check the previous version and then
I download and install the appropriate files.
Prior to the most recent update, I changed my LM, so I created a backup
of all the configurations and then restored it to the new LM.
The only bug that could cause this mess, is if the backup/restore
process caused the LM to show the wrong version.
For me it is solved, so thank you for the help.
Backup does not contain this information. It cannot change the firmware version information.
(Yesterday, 06:51)Daniel Wrote: Backup does not contain this information.  It cannot change the firmware version information.
Then, it entirely my fault.
Thanks for your help.
