Page opening at event
Is it possible to open a page with an event, is it possible to put the page in front without changing the background page?
tank's
Claudio
Which visualization tool do you use?
(10.09.2025, 09:43)Daniel Wrote: Which visualization tool do you use?
Visu.
Custom JS:
localbus.listen('object', '0/0/1', (value) => {
  if (value) {
    Visu.showPlan(12);
  else {
    Visu.showPlan(5);
Replace number with visu page id found in URL: http://192.168.0.10/apps/data/visu/#12
Visu.showPlan(12) is when ga 0/0/1 is ON and  Visu.showPlan(5); is when 0/0/1 is OFF
If it is for a doorbell, you can put an event script on 0/0/1 to set it back to OFF after a certain time
Visu.
I need this on old visu where do I find the page number?
Old visu use different, see this
https://forum.logicmachine.net/showthread.php?tid=275
