Threads: 76
Good morning,
I have a problem in this resident script.
Code: function calcolo32bit (data)
if data[3] then
--log('sono passato', data)
local byte_1 = data[6]
local byte_2 = data[5]
local byte_3 = data[4]
local byte_4 = data[3]
byte_received = ((byte_4 * 16777216)+(byte_3 * 65536)+(byte_2 * 256)+byte_1)
--log(byte_received)
s = bit.rshift(byte_received, 31)
--log(s)
exp1 = bit.rshift(byte_received, 23)
--log(exp1)
matissa = bit.band(byte_received , 8388607)
--log(matissa)
matissa2 = (matissa * 0.0000001) + 1
--log(matissa2)
risultato = (((-1)^s) * (2^(exp1-127))* matissa2)
return(risultato)
return(0)
function crc_calc(inv,cmd_set)
inv_num = {0x02,0x03,0x04,0x05,0x06,0x07}
--log('inv_num',inv_num[inv])
cmd = {{0x32,0x20,0x20,0x20,0x20,0x20,0x20},
{0x3B,0x01,0x00,0x20,0x20,0x20,0x20},
{0x3B,0x02,0x00,0x20,0x20,0x20,0x20},
{0x3B,0x03,0x00,0x20,0x20,0x20,0x20},
{0x3B,0x04,0x00,0x20,0x20,0x20,0x20},
{0x3B,0x08,0x00,0x20,0x20,0x20,0x20},
{0x3B,0x09,0x00,0x20,0x20,0x20,0x20},
{0x3B,0x1E,0x00,0x20,0x20,0x20,0x20},
{0x3B,0x31,0x00,0x20,0x20,0x20,0x20},
{0x4E,0x00,0x20,0x20,0x20,0x20,0x20},
{0x4E,0x01,0x20,0x20,0x20,0x20,0x20},
{0x4E,0x03,0x20,0x20,0x20,0x20,0x20},
{0x4E,0x04,0x20,0x20,0x20,0x20,0x20},
{0x4E,0x05,0x20,0x20,0x20,0x20,0x20}}
data = string.char(inv_num[inv],cmd[cmd_set][1],cmd[cmd_set][2],cmd[cmd_set][3],cmd[cmd_set][4],cmd[cmd_set][5],cmd[cmd_set][6],cmd[cmd_set][7])
--log('valore grezzo = ',data)
crc_calc = crc16(data)
--log(crc_calc)
return (crc_calc)
for i = 1, 6, 1 do
--log(i)
crc = crc_calc(i,1)
--log(crc)
The first time (i = 1) it works, then it broken and says this error
Code: Power_one 10.09.2025 13:10:53
Resident script:164: attempt to call global 'crc_calc' (a string value)
stack traceback:
I can't understand what is it the problem.
Can someone help me? Please
B.R. Cristian
Threads: 14
if data[3] then
--log(s)
--log(exp1)
--log(matissa)
--log(matissa2)
return(risultato)
return(0)
local crc_result = crc16(data) -- use different name
--log(crc_result)
return (crc_result)
for i = 1, 6, 1 do
--log(i)
crc = crc_calc(i,1)
--log(crc)
hello, try this
Threads: 76
(10.09.2025, 11:27)hocine Wrote: Code: function calcolo32bit (data)
if data[3] then
--log(s)
--log(exp1)
--log(matissa)
--log(matissa2)
return(risultato)
return(0)
--log(crc_result)
return (crc_result)
for i = 1, 6, 1 do
--log(i)
crc = crc_calc(i,1)
--log(crc)
hello, try this Hi,
thanks but it is the same error. Always first step and then error.
BR Cristian
Threads: 30
Where did you get this function from? crc16(data)
Threads: 76
(10.09.2025, 11:48)Daniel Wrote: Where did you get this function from? crc16(data)
sorry i forget to attached a part...... here for you
Code: --funzione calcolo CRC16
function crc16(data)
log('valore passato = ',data)
local crc = 0xFFFF
for i = 1, #data do
crc = bit.bxor(crc, data:byte(i))
for j = 1, 8 do
local k = bit.band(crc, 1)
crc = bit.rshift(crc, 1)
if k ~= 0 then
crc = bit.bxor(crc, 0x8408)
--return bit.bxor(crc, 0xFFFF)
result = string.format("%04X",bit.bxor(crc, 0xFFFF))
result_low = string.sub(result, 3 , 4)
result_high = string.sub(result, 1 , 2)
crc_calc = (',0x'..result_low..',0x'..result_high)
return crc_calc
Threads: 30
Try this
if data[3] then
--log(s)
--log(exp1)
--log(matissa)
--log(matissa2)
return(risultato)
return(0)
-- log('valore passato = ',data)
local crc = 0xFFFF
for i = 1, #data do
for j = 1, 8 do
if k ~= 0 then
local crc16 = (',0x'..result_low..',0x'..result_high)
return crc16
crc1 = crc16(data)
--log(crc_calc)
return (crc1)
for i = 1, 6, 1 do
local crc = crc_calc(i ,1)
log(crc)
Threads: 76
(10.09.2025, 13:32)Daniel Wrote: Try this
if data[3] then
--log(s)
--log(exp1)
--log(matissa)
--log(matissa2)
return(risultato)
return(0)
local crc = 0xFFFF
for i = 1, #data do
for j = 1, 8 do
if k ~= 0 then
return crc16
crc1 = crc16(data)
--log(crc_calc)
return (crc1)
for i = 1, 6, 1 do
log(crc)
thank you so much in this way it works.
So error was in crc16 function.
BR Cristian
