(30.09.2025, 08:22)admin Wrote: Disable both NTP server and client in system config. Create a resident script with sleep time set to 5 seconds. You can replace region (europe) with 2-letter country code (de, fr, etc) for more precise time updates.
reg = 'europe'
cmd = '/usr/sbin/ntpd -ddd -l -n -p 0.%s.pool.ntp.org -p 1.%s.pool.ntp.org -p 2.%s.pool.ntp.org -p 3.%s.pool.ntp.org 2>&1'
cmd = string.format(cmd, reg, reg, reg, reg)
proc = io.popen(cmd)
while true do
line = proc:read()
if line then
if line:find('responded to query from') then
ip = line:match('%d+%.%d+%.%d+%.%d+')
log('NTP query', ip)
break
proc:close()
Hi admin,
Many thanks!
I will test the script and give feedback
(30.09.2025, 09:11)CHOUAIBOU Wrote: (30.09.2025, 08:22)admin Wrote: Disable both NTP server and client in system config. Create a resident script with sleep time set to 5 seconds. You can replace region (europe) with 2-letter country code (de, fr, etc) for more precise time updates.
reg = 'europe'
while true do
line = proc:read()
if line then
break
proc:close()
Hi admin,
Many thanks!
Hi admin,
The script is working fine. The LM is not actually connected to the internet.
I am using my Laptop NTP server.
Thanks!
Below the logs:
LM_As_NTP_Server_Debugger 30.09.2025 12:00:35
* string: ntpd: sending query to 10.195.221.101
* string: ntpd: reply from 10.195.221.101: offset:+0.000217 delay:0.002551 status:0x24 strat:1 refid:0x4c434f4c rootdelay:0.000000 reach:0x7f
* string: ntpd: update from:10.195.221.101 offset:+0.000217 delay:0.002551 jitter:0.002000 clock drift:+0.329ppm tc:5
* string: ntpd: poll:32s sockets:1 interval:32s
LM
