LG smart TV
Does anybody have a script to control LG smart TV over IP?
(13.02.2017, 16:53)Desislav Wrote: Hello,
Yes is it possible to change this python script to lua ? see : https://github.com/ubaransel/lgcommander
This is a script to control a LG smart TV.
anybody was try to control from LUA ?
Here is websocket script. I've tried, but something did wrong. If anyone could use it and make LG TV control, it would be great.
https://forum.logicmachine.net/showthrea...=websocket
Attached you can find the library to control LG TV with Web OS.
It uses Lua websocket library from here https://github.com/lipp/lua-websockets. Websocket library is also available in this forum.
Just change the name of the library to yours in the coding ('user.websocket_client_sync')
It was inspired by Node.JS module https://github.com/hobbyquaker/lgtv2, you can also find a list of commands and configuration instructions there.
Coding is published as is , errors are possible Smile
The following command will turn Off the LG TV . 2 constants below are the IP address of the LG TV and the KNX group address to store the handshake key.
lg_execute_command(LGTV65_IP, LGTV65_KEY, "", "request", "ssap://system/turnOff", "")
.lua   lgtv.lua (Size: 7.41 KB / Downloads: 12)
