Save & Restore State
Hi Guys,
I do have few objects for lighting control which are exported into bacnet and we control them from the bacnet...
I will creat another object in the LM5 that turns ON all of the lights, and instead of switching OFF, we want to restores each light to its previous state?
I need a method to store the current values and write them back after the override.
Any examples or script are appreciated.
Why don't you just create another global group in KNX for all lights and use it to control all. Then you need another group for bacnet to send on/off and for ON you send 1 to all lights group and for OFF you read state of all individual groups and re-send its value.
(14.11.2025, 09:04)Daniel Wrote: Why don't you just create another global group in KNX for all lights and use it to control all. Then you need another group for bacnet to send on/off and for ON you send 1 to all lights group and for OFF you read state of all individual groups and re-send its value.
I can create the global group but i can't change the bacnet objects because i do not have any control to the BMS system...
What is going to trigger the restoring of value state?
(14.11.2025, 09:32)Daniel Wrote: What is going to trigger the restoring of value state?
1bit virtual object (will be controlled from mosaic)
It makes no difference, the whole point is to make global command separate from individual groups. The individual groups will store old value and you can use it.
