Threads: 10
09.12.2025, 05:04
(This post was last modified: 09.12.2025, 05:05 by 2MAX.)
can somebody help me with creating script to unlock relay on hikvision door unit KD-8003. I kow IP adress and password too.
i find this info from Hikvision
Code: curl Command Example
You can use the following curl command in a shell script, replacing the placeholders with your device's actual information:
bash
curl -i --digest -u admin:YOUR_PASSWORD -X PUT -d '<RemoteControlDoor><cmd>open</cmd></RemoteControlDoor>' http://<DEVICE_IP_ADDRESS>/ISAPI/AccessControl/RemoteControl/door/1
Při použití kódu buďte obezřetní.
admin:YOUR_PASSWORD: Replace YOUR_PASSWORD with the admin password you set during activation.
<DEVICE_IP_ADDRESS>: Replace with the actual LAN IP address of your KD-8003 door station (e.g., 192.168.1.65).
door/1: This targets the first relay/lock. If you have a second lock configured, you can change this to door/2.
--digest: This is important as Hikvision devices typically use Digest Authentication for ISAPI requests.
Try this, change URL as needed. Make sure that you don't have @ character in the password.
Code: url = 'http://admin:PASSWORD@192.168.1.1/ISAPI/AccessControl/RemoteControl/door/1'
local skthttp = require('socket.http')
local skturl = require('socket.url')
local ltn12 = require('ltn12')
local md5sum = require('encdec').md5
local hash = function(...)
return md5sum(table.concat({...}, ':'))
local parse_header = function(header)
local result = {}
for key, value in (header .. ','):gmatch('(%w+)=(.-),') do
if value:sub(1, 1) == '"' then -- strip quotes
result[ key:lower() ] = value:sub(2, -2)
return result
local make_digest_header = function(headers)
local digest = {}
for _, header in ipairs(headers) do
if not header.unquote then
header[ 2 ] = '"' .. header[ 2 ] .. '"'
digest[ #digest + 1 ] = header[ 1 ] .. '=' .. header[ 2 ]
return 'Digest ' .. table.concat(digest, ', ')
local _request = function(req)
if not req.url then
return nil, 'missing url'
local url = skturl.parse(req.url)
local user, password = url.user, url.password
if not user or not password then
return nil, 'missing credentials in url'
url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil
req.url = skturl.build(url)
local source
if req.source then
local chunks = {}
local capture = function(chunk)
if chunk then
chunks[ #chunks + 1 ] = chunk
return chunk
local chunk_id = 0
source = function()
chunk_id = chunk_id + 1
return chunks[ chunk_id ]
req.source = ltn12.source.chain(req.source, capture)
local body, code, hdrs = skthttp.request(req)
if code == 401 and hdrs['www-authenticate'] then
local ht = parse_header(hdrs['www-authenticate'])
if not ht.realm or not ht.nonce then
return nil, 'missing realm/nonce from response'
if ht.qop ~= 'auth' then
return nil, 'unsupported qop ' .. tostring(ht.qop)
if ht.algorithm and ht.algorithm:lower() ~= 'md5' then
return nil, 'unsupported algo ' .. tostring(ht.algorithm)
local nc = '00000001'
local cnonce = string.format('%08x', os.time())
local uri = skturl.build({ path = url.path, query = url.query })
local method = req.method or 'GET'
local response = hash(
hash(user, ht.realm, password),
ht.nonce,
nc,
cnonce,
'auth',
hash(method, uri)
req.headers = req.headers or {}
local auth = {
{ 'username', user },
{ 'realm', ht.realm },
{ 'nonce', ht.nonce },
{ 'uri', uri },
{ 'cnonce', cnonce },
{ 'nc', nc, unquote = true },
{ 'qop', 'auth' },
{ 'algorithm', 'MD5' },
{ 'response', response },
if ht.opaque then
table.insert(auth, { 'opaque', ht.opaque })
req.headers.authorization = make_digest_header(auth)
if not req.headers.cookie and hdrs['set-cookie'] then
-- not really correct but enough for httpbin
local cookie = (hdrs['set-cookie'] .. ';'):match('(.-=.-)[;,]')
if cookie then
req.headers.cookie = '$Version: 0; ' .. cookie .. ';'
if req.source then
req.source = source
return body, code, hdrs
local request = function(url)
local t = type(url)
if t == 'table' then
return _request(table.clone(url))
elseif t == 'string' then
local req = {}
local _, code, headers = _request({ url = url, sink = ltn12.sink.table(req) })
return table.concat(req), code, headers
res, err, hdrs = request({
url = url,
method = 'PUT',
body = '<RemoteControlDoor><cmd>open</cmd></RemoteControlDoor>'
log(res, err, hdrs)
