05.04.2026, 20:46
I have an object from ETS 31/0/45 but this object is not displayed in the Object tab. Also I can not add another object with the same address.
If I find ID thru
and delete this object with "grp.delete(id)", and then add it manually, the operation is successful but it again dissapears from the list.
Could you advice?
If I find ID thru
local obj = grp.find('31/0/45')
if obj then
for k,v in pairs(obj) do
log(k .. ' = ' .. tostring(v))
log('not found')
endCould you advice?
