Threads: 103
Can I modify scenes defined in LM in visualisation?
I mean change of brightness, room temperature etc.
"Autolearn" button would be great too.
Thank you
Threads: 7
Hi Thomas,
Not yet (for now you need to login to configuration part), but i have plans to create a app for this so end user can change and define his own scenes.
Threads: 103
Can I access scene objects from Lua? If so I can simulate the required "Save" button in this way.
Available functions:
Code: scene.run = function(alias)
run scene, alias can be a name or an id
scene.savelive = function(alias)
save live value for the given scene alias
scene.set = function(alias, active)
enable/disable scene, this will only disable running the scene
by sending a specified value to trigger object. scene can be
still executed via run() no matter if it is enabled or not
scene.enable = function(alias)
shortcut for scene.set(alias, true)
scene.disable = function(alias)
shortcut for scene.set(alias, false)
scene.status = function(alias)
returns true when scene is enabled, false otherwise
scene.tagset = function(tag, active)
enable/disable all scenes having the given tag
scene.tagenable = function(tag)
shortcut for scene.tagset(tag, true)
scene.tagdisable = function(tag)
shortcut for scene.tagset(tag, false)
scene.tagstatus = function(tag)
returns two values: number of enabled and disabled scenes
for the given tag
scene.tagsavelive = function(tag)
save live values for all scenes having the given tag
scene.tagrun = function(tag)
run all scenes having the given tag
Threads: 161
How can I use these functions? What do you mean by scene object? 1byte object?
This is only available in newer firmwares which are not published yet
Threads: 161
(23.02.2017, 18:06)admin Wrote: This is only available in newer firmwares which are not published yet
Super info, I am waiting for publishing
Threads: 7
23.02.2017, 23:49
(This post was last modified: 24.02.2017, 00:02 by Erwin van der Zwart.)
Hi Admin,
Will there also be a mapping option added for 1 byte feedback to 1 byte value when using 4bit dimming? Issue is when you use 4 bit dimming from sensor the feedback is update only, and value object doesn't have this latest value. So when you save live values the value object might have different value then the real dimming value (as send by feedback object).
I noticed also the function scene.reload() that is not specified in your list, what does it do?
Reload is used to tell the scene handler to reload scene data from the database. It is used by functions like enable/disable and should not usually be run manually. For now status objects won't be supported, but we might look into it later on.
Threads: 12
please add timouts between sending telegrams
Threads: 103
Can I get scene table by some search function? Like I can use
myobjects = grp.tag('tag name')
for getting a list of group objects tables.
Thank you
Do you want to get get a list of all scenes? Then the only way for now is to a database query:
Code: scenes = db:getall('SELECT * FROM scenes')
Threads: 103
(29.11.2017, 07:28)admin Wrote: Do you want to get get a list of all scenes? Then the only way for now is to a database query:
Thank you
Threads: 38
28.07.2020, 10:58
(This post was last modified: 28.07.2020, 10:59 by Trond Hoyem.)
(23.02.2017, 16:31)admin Wrote: Available functions:
for the given tag
I am not able to do this. I every time get an error stating; attempt to call field 'savelive' (a nil value)
The code is
Code: if scene > 0 and scene < 63 then
scene.savelive(navn)
Am I missing something, or just doing it wrong?
There are 10 kinds of people in the world; those who can read binary and those who don't
That's because you have overridden scene table with a numeric variable, rename scene number variable to something else in your script.
Threads: 38
(28.07.2020, 11:00)admin Wrote: That's because you have overridden scene table with a numeric variable, rename scene number variable to something else in your script. Of course...
Thx for the patience
