Button input
I want to use button input to play/pause music and use wiring diagram of datasheet but it's not working. What should i do?
Huh
did you enable specific button control in Quick Setup?
How did you connect wires (one wire to Button port, another to GND port?)
(24.02.2017, 09:00)edgars Wrote: did you enable specific button control in Quick Setup?
yes i enabled them in Quick Setup
yes i connect one wire to button port and another to GND port
Huh
What power supply are you using? The button inputs were designed to work with 24V and might not work with lower voltage.
(27.02.2017, 07:20)admin Wrote: What power supply are you using? The button inputs were designed to work with 24V and might not work with lower voltage.
ooooh i use 12v power supply. I will change it. thanks
