25.06.2026, 10:47
I would like to clarify the supported behavior of the HTML widget in the new LogicMachine visualization.
Questions
Thank you.
Questions
- Does the HTML widget in the new visualization support inline / embedded JavaScript execution, or is it limited to HTML/CSS rendering only?
- Is Custom JavaScript in the new visualization supposed to interact with DOM elements created inside an HTML widget?
- If we build a custom HTML-based interface in the new visualization, is there any officially supported way to trigger KNX writes (switch / dimming / RGB values) from that interface?
- If not, is the recommended approach to use native LM widgets only for all control logic in the new visualization?
Thank you.
