Error during export objectlogs
I am logging several values in the objectlogs tab. When I try to export them I get the following error in a new safari-tab:
Error: /lib/genohm-scada/web/objectlogs/csv.lua:10: unexpected symbol near '='
Any ideas how to resolve this?
Thanks, Bart
Hi Bart,
Not sure, but it looks like you are using special sign in you object names and that might cause a error in the CSV notation.. are you using ' or '' signs or , in your object names?
It's a bug in the FW, we will fix it in the next release.
(11.03.2017, 22:51)Erwin van der Zwart Wrote: Hi Bart,
Hi Erwin,
Only minus-sign nothing else.
I have attached a screendump.
Mvg, Bart
(12.03.2017, 10:22)admin Wrote: It's a bug in the FW, we will fix it in the next release.
Hi Admin,
Any ideas how to get a logfile (csv) for a set of grpadresses?
I would need a 2 day logging of the weatherstation since it is giving wrong values (it is currently more than 50 degrees C in Belgium according to the station Smile ) - need to send it to the supplier.
Best regards,
Bart
Hi Bart,
This script creates a csv of the object logs on your ftp folder:
-- get past year data
logtime = os.time() - 60 * 60 * 24 * 365
-- list of objects by id
objects = {}
-- objects with logging enabled
query = 'SELECT address, datatype, name FROM objects WHERE disablelog=0'
for _, object in ipairs(db:getall(query)) do
 objects[ tonumber(object.address) ] = {
   datatype = tonumber(object.datatype),
   name = tostring(object.name or ''),
-- csv buffer
buffer = { '"date","address","name","value"' }
-- get object logs
query = 'SELECT src, address, datahex, logtime, eventtype FROM objectlog WHERE logtime >= ? ORDER BY id DESC'
for _, row in ipairs(db:getall(query, logtime)) do
 object = objects[ tonumber(row.address) ]
 -- found matching object and event type is group write
 if object and row.eventtype == 'write' then
   datatype = object.datatype
   -- check that object datatype is set
   if datatype then
     -- decode data
     data = knxdatatype.decode(row.datahex, datatype)
     -- remove null chars from char/string datatype
     if datatype == dt.char or datatype == dt.string then
       data = data:gsub('%z+', '')
     -- date to DD.MM.YYYY
     elseif datatype == dt.date then
       data = string.format('%.2d.%.2d.%.2d', data.day, data.month, data.year)
     -- time to HH:MM:SS
     elseif datatype == dt.time then
       data = string.format('%.2d:%.2d:%.2d', data.hour, data.minute, data.second)
     data = ''
   -- format csv row
   logdate = os.date('%Y.%m.%d %H:%M:%S', row.logtime)
   csv = string.format('%q,%q,%q,%q', logdate, knxlib.decodega(row.address), object.name, tostring(data))
   -- add to buffer
   table.insert(buffer, csv)
dst = '/home/ftp/logs.csv'
io.writefile(dst, table.concat(buffer, '\r\n'))
(13.03.2017, 22:46)Erwin van der Zwart Wrote: Hi Bart,
objects = {}
-- csv buffer
-- get object logs
   if datatype then
     -- decode data
     -- time to HH:MM:SS
     data = ''
   -- format csv row
   -- add to buffer
Thanks Erwin!
This only work if I have objects, and if objects are mark as log.
If I want to get all traffic in knx without mark the log field, because there is some knx device that i have not control over it, and it send me each time some unknown data, that I have not in the object table.
I just want to send all trafic on KNX bus each 1 hour, even if I have not objects created in my LM5. Could it be posible???
You could try to enable auto object creation in the general settings and set the log policy to all objects.
This way there will be a object created when the telegram holds a valid KNX structure and the logging will be activated already because you log all objects including the new ones..
