Threads: 7
27.04.2017, 14:49
(This post was last modified: 27.04.2017, 16:11 by Erwin van der Zwart.)
main.asp is a active server page, so a webpage that holds your stream in a element. The URL in the controller cannot be a webpage (you could try a widget with a iframe)
Otherwise you have to explore the source of your asp to retrieve the actual URL to your cam.
Threads: 13
Look for the actual URL of the camera, but still this does not work, also try to put the URL of the page google, but neither is taking. What could be happening?
Threads: 7
Are you using a frame or a camera element in your visu?
If you are using the camera element you cannot use a url to a website like google, also google does not work in a frame as they don't allow framing.
Threads: 13
Now I'm working with camra d-link 930L but in the logic in the camera only shows me screenshots, when I put the video url does not show anything. What could be happening?
Threads: 0
I want to use different IP camera brands (Ezviz and Tapo, because there are existing camera's and new camera on this project) for video surveillance and combine with Akuvox video door communication. Is there a way to embed snapshots from these cameras to Mosaic visualisation?
Threads: 28
We don't have these cameras to test, you need to check it out.
