DALI motion sensors and DT8
1. Does LM support DT8 (Colour control) DALI devices? For example this dimmer
2. Does LM support DALI motion detectors? For example this one
Only standard DALI commands are supported, multi-master mode (needed for any kind of sensors) is not supported.
http://www.dali-ag.org/discover-dali/dali-standard.html
DT8 should be standard DALI command, isn't it?
If it could be helpful, the DALI-KNX gateway from Schneider Electric supports DT8 ballasts, from this point on, I have not yet integrated this type of ballast, so I do not tell you the compatibility with the object data and the LM or HL ...
Let's see if anyone in the forum has been able to work with dt8 and HL or LM.
Greetings colleagues  Wink
Correct, we support DT8 on MTN6725-0001 (from gateway FW 1.3)
From HL you can control the templates to set RGB or K values.
(02.05.2017, 15:15)Erwin van der Zwart Wrote: Hi,
how is HL done to perform this type of RGB control?
in ETS5 only appears to me to realize regulation, connection, value and states
Regards
See page 32 to 34 of this document: http://download.schneider-electric.com/f..._2016_4_EN
(28.04.2017, 06:42)admin Wrote: Only standard DALI commands are supported, multi-master mode (needed for any kind of sensors) is not supported.
does this mean, that LM integrated DALI gateway will not support DT8 devices? Or is an integration of DT8 into LogicMachine native gateway planned for foreseeable future?
I would gladly test it, because I have an installation where a single DT8 device has been added by a client and now I am unable to integrate it Sad
Thank you,
Jakub
