Threads: 101
My error log contains every 2 minutes:
scriptname: mcloud or alexa
error: Row 350: MQTT.client:handler(): Not connected
Threads: 99
what is ping reply to cloud.logicmachine.net in System config --> Status --> Network Utilities?
Did you succeed to adding account for cloud and syncing the Alexa objects?
Also, make sure your routers are passing through ports 443 (HTTPS) and 1883 (MQTT).
Threads: 3
I also have this bug
Threads: 99
1. please check if you have correct gateway, DNS settings on LM
2. Could be so that MQTT port is blocked on the router?
3. If possible we would like to connect and see this controller (ports 22 and 80). Please PM me if this is possible.
Threads: 99
German language support added. Also now LogicMachine skill can be found also in Amazon UK servers.
Threads: 99
Alexa app is now available in LogicMachine app store.
We have fixed a bug when your Alexa voice commands might not work if you were using Mosaic cloud application in parallel.
Threads: 2
Dear edgars
I updated alexa app with new fw. But alexa app not work.
Please help me to check it.
Thank you so much
Error in /www/apps/data/alexa/index.lp at line 4: attempt to call global 'auth_client' (a nil value)
Threads: 2
Hi Edgars,
I installed this file but alexa app still error.
Please chek it.
Thank you
Threads: 99
uninstall Alexa app and install it again, then it should be fine. Make sure you are running latest firmware on LM.
Threads: 10
Hi, I am running the latest LM4 RC3 firmware and App versions (Alexa 20170531 and Mosaic 2.0: 20170613) but I am still getting error logs of "Line 350: MQTT.client:handler(): Not connected" and more importantly, the commands I give are randomly executed by LM, even though Alexa understands and acknowledge them normally with "ok".
Anyone experiencing similar issues or is just my problem?
Threads: 10
Can anyone who uses Alexa app confirm that is working flawlessly?
