Threads: 20
I want to create >100 trend logs (each about 0.4mb). So where these logs are stored on LM and is it possible I run out of storage by doing this?
As I noticed, when I create logs System Status -> Memory increases, which is total of 122mb. Can I store those logs in other place, for example System Status -> Partitions -> /dev/mmcblk0p3, there are free 3.5gb space.
Leonidas.
Trends and main db is stored in RAM and is copied to SD every 30 minutes. This is a must to prolong SD card lifetime. The maximum number of space that trends can use is limited in the current RC firmware.
Threads: 20
OK, thanks. Seems like I will run out of space with 100 trends..
Threads: 31
(18.03.2019, 13:30)Kai-Roger Wrote: (17.05.2017, 08:05)admin Wrote: ~30MB
Hi.
Why is there so little storage for the trend logs? Becouse of total available RAM?
Kai-Roger
30MB was on hardware without SPI and yes this limit was due to RAM. On hardware with SPI the limit is around 21MB due to SPI size.
Threads: 31
(18.03.2019, 14:12)Kai-Roger Wrote: (18.03.2019, 13:56)Daniel. Wrote: (18.03.2019, 13:30)Kai-Roger Wrote: (17.05.2017, 08:05)admin Wrote: ~30MB
Hi.
Kai-Roger
Is it the same limit on the newest LM5?
yes
Threads: 19
20.05.2019, 15:02
(This post was last modified: 20.05.2019, 15:02 by manos@dynamitec.)
Hello All,
Are the trend logs overwritten in case of a project restore? If yes is there a way I could download the data and re-upload them after the project upload?
Thank you in advance
Trend logs are part of whole backup. There's no built-in way to do partial backup restore. For trends this is not trivial because each trend log is stored as a separate file and there are also main database entries.
Threads: 31
It depend of what changes you want to make. If you want to update just scripts or visu then this you can backup separately and restore on site.
