Hide explorer
How can I hide the top bar of the browser in the view automatically?
(18.07.2017, 07:05)Daponte Wrote: How can I hide the top bar of the browser in the view automatically?
Hi, you should add link for visu page to homepage of iOS or Android.
then visualisation will open in full screen mode
Automatically I do not know, but here is what I use with a click...
JMM.
$('#plan-7' ).on( 'vclick', function() {
 toggleFullScreen();
 showPlan(7); // resize plan.
function toggleFullScreen() {
 if (!document.fullscreenElement &&    // alternative standard method
     !document.mozFullScreenElement && !document.webkitFullscreenElement) {  // current working methods
   if (document.documentElement.requestFullscreen) {
     document.documentElement.requestFullscreen();
   } else if (document.documentElement.mozRequestFullScreen) {
     document.documentElement.mozRequestFullScreen();
   } else if (document.documentElement.webkitRequestFullscreen) {
     document.documentElement.webkitRequestFullscreen(Element.ALLOW_KEYBOARD_INPUT);
 } else {
   if (document.cancelFullScreen) {
     document.cancelFullScreen();
   } else if (document.mozCancelFullScreen) {
     document.mozCancelFullScreen();
   } else if (document.webkitCancelFullScreen) {
     document.webkitCancelFullScreen();
Jean-Marc
What I needed was to open scada, in full mode as if we pressed F11
And well the script which I propose make exactly the same thing as F11
JMM.
Jean-Marc
(18.07.2017, 11:16)Daponte Wrote: Hello,
create a shortcut for chrome.exe and change linc to object like this:
"C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --kiosk "http://192.168.0.39"
but if any another tab of chrome is opened it won't work.
just tested
if you want to open visualisation the link should be like this
http://192.168.0.39/scada-vis
just set your LMs IP
thank you,
