03.08.2017, 08:05
Being new to LUA I´m finding it difficult to get everything right. Could some one help me with below.?? Please
I have tried to create a simple Staircase timer for lighting control with the following functions:
1bit KNX command = true activates (From presence detector)
(1.) Sends a KNX Byte value "90%"
(2.) After not receiving (1bit from presence detector) in 30 min send KNX byte value 20%
(3.) After not receiving (1bit from presence detector) in 60 min send KNX byte value 0%
(( If triggered by 1bit from presence detector it should re-trigger the staircase timer.))
I need to run multiple staircase timers for different areas with the same LM unit.!
