Threads: 161
is it possible to customize GA priority on LM? I see such option in the ETS, how can I implement it on LM?
Not possible internally right now, though priorities set by ETS are sent to KNX bus unchanged. Are you missing some telegrams that you need this feature? Usually, only system messages must have higher priority, all group telegrams should have the lowest priority.
Threads: 103
this is the same problem as acking / ignoring telegrams not processed in LM. Or lack of dummy object. If you have five KNX devices on the bus then it doesn't matter. If you have hundreds of devices in ten lines then missing priorities can be a problem in such cases.
