LogicMachine3 Re:actor 24 V Output not working
I have the LogicMachine3 Re:actor and was trying to start using the digital outputs to control some relays. However, I am not able to measure a voltage between any of the digital outputs and 24 V Output ground. There is no voltage in the 24 V Ouput, either.
Any thoughts? Is there a hardware malfunction in my unit? What should I check?
Best regards,
Vesa
In LM3:Reactor have 2 pin power supply. Did you supply power for them?
Big Grin
Thanks & Best Regards
(17.08.2017, 09:10)nhieulk Wrote: Hi,
Big Grin
I was using this wiring diagram from the manual:
where there is the label 24 V Output below the red and black connectors on the top left. Now it seems to me that I should actually connect these to the power supply to have it supply power to the digital outputs.
Big Grin
This did not solve the problem. There is no voltage in the outputs even though I can see from the web interface that the outputs are on.
Vesa
Are you sure that you have correct firmware ?
(22.08.2017, 08:19)morak Wrote: Hi
The firmware was incorrect. Now it works perfectly.
Thank you.
Vesa
