guidance on databases in logic machine
Hello, Sorry for asking a lot, but you do not find many
things about the logical machine, like on this site
When working with MySQL database in logic machine, what user,
database name, server, and password should I connect to? A logic machine? How
do I know what it is?
After
When I want to select a table like I know the name of the table that I have to select? With their respective fields or columns, a serious example would be: select the database the group address with its data type, current value, and date on which current value update of that group address
Then I could send that data obtained from outside the logic machine,
from the application of the logic machine and take it to my application to read
those data from the database of the logic machine?
In most cases you don't need to access internal database directly but use provided functions instead. To get all objects you can use grp.all(): http://openrb.com/docs/lua.htm#grp.all
Here's an example that logs group address, name and current value for first 5 objects:
objects = grp.all()
for i, object in ipairs(objects) do
  log(object.address, object.name, object.value)
  if i == 5 then
    break
(07.09.2017, 06:04)admin Wrote: In most cases you don't need to access internal database directly but use provided functions instead. To get all objects you can use grp.all(): http://openrb.com/docs/lua.htm#grp.all
objects = grp.all()
 if i == 5 then
   break
Hi,thank you very much if it works for me
