Create Modbus client via script
#21
SHAC/NAC has different database structure and most likely this will require some modification. You can only map it to 250/ and you have much less dpts to select from.
SHAC/NAC does not have the option to link multiple objects at once. There were some works to add it to upcoming 2.0.0 but I haven't seen it yet.
(08.12.2020, 07:36)Erwin van der Zwart Wrote: Not that i know of, but I assume the modbus part is exactly the same in a SHAC/NAC and that the difference is only in the group address format.
We don’t need this script anymore for our KNX models as it’s now embedded in the FW/GUI of the latest FW 2.5.1...
Thanks Erwin, I think the line "dec_grp_address = knxlib.encodega(grp_address)" is what will differ - I'll check with Clipsal in Adelaide to see if they have a similar function.
