this conexion to the database is posible? using phpmyadmin?
Hi  to all
it is possible to make this connection to my local server using xampp and phpmyadmin use the following address
localhost / phpmyadmin
Yes, but instead of localhost you must put your remote server IP address. Check MySQL priviliges that user can connect from remote IPs. Also, your script has incorrect variable naming, user this example and do not change variable names:
https://forum.logicmachine.net/showthrea...798#pid798
by the help
Thanks You!
Smile Big Grin Big Grin Big Grin Big Grin Big Grin Big Grin Big Grin Big Grin
