22.02.2018, 10:56
Hi all as a contribution here after you will find my code done to pilot a Nabaztag
as a reminder Nabaztag is a communicating rabbit, that can speak(TTS), play music, move ears, have an embded RFID sensor. I personnaly use it as vocal feedback of my homeautomation system (homelynk based)
Author: Gilles38
Version: 0.0.1
Design for HomeLYnk and spaceLYnk
Available methodes:
Is_Reachable() return boolean
Is_Connected() return boolean
Is_Sleeping() return boolean
Reboot() return true or error message
SetEars($Pos_Gauche,$Pos_Droite) return true or error message
Speak($Texte,$Voix) return true or error message
Play_Stream($Url) return true or error message
Get_Name() return string
Get_Voices() return array
Wakeup() return true or error message
Goto_Sleep() return true or error message
Required for constructor:
Adresse_main:define standard server adresse
Adresse_Unified: define alternativ server
Name: is the name of the Rabbit
Token: define the token of the rabbit
Mac: Mac adress of the rabbit
Voice: define the list of voices available
Nabaztag={Name="",Token="",Mac="", Adresse_Main="", Adresse_Unified="", Voice={}}
Nabaztag.__index = Nabaztag
--Nabaztag class constructor
function Nabaztag:new( o,Name, Token, Mac)
o=o or {}
setmetatable(o, self)
self.Name = Name
self.Token = Token
self.Mac = Mac
self.Adresse_Main="http://openjabnab.fr/ojn/FR/api.jsp"
self.Adresse_Unified="http://api.wizz.cc/?server=pixel"
self.Voices= {"Alice","Antoine","Bruno","Claire","Julie","Margaux","Lorise","Deepa","Graham","Lucy","Peter","Rachel"}
log("Creation classe name:"..self.Name.." Token:"..self.Token)
return o
--Send standard command to Nabaztag return true or false
function Nabaztag:Send_Command(action)
Query=self.Adresse_Main.."?sn="..self.Mac.."&token="..self.Token.."&action="..action
return(self:Launch_Query(Query))
function Nabaztag:Launch_Query(Query)
log("Launch-Query")
require ("socket")
require ("socket.http")
respResult, respcode, respHeaders, respStatus = socket.http.request(Query)
return(respResult)
--************Get Rabbit name**********
function Nabaztag:Get_name()
return(self.Name)
--**********Get voices available*******
function Nabaztag:Get_Voices()
return(self.Voices)
--************Goto slip****************
function Nabaztag:Goto_Sleep()
return(self:Send_Command(14))
--**********Make the rabbit wakeup**********
function Nabaztag:Wakeup()
return(self:Send_Command(13))
--*********Play sounds from URL***********
function Nabaztag:Play_Stream(Url)
Query=self.Adresse_Unified.."&sn="..self.Mac.."&token="..self.Token.."&urlList="..Url
result=self:Launch_Query(Query)
--********Make the rabbit speak**********
function Nabaztag:Speak(Text,Voice)
--*******Url encode**********
if (Text) then
Text = string.gsub (Text, "\n", "\r\n")
--Text = string.gsub (Text, "([^%w ])",
-- function (c) return string.format ("%%%02X", string.byte(c)) end)
Text = string.gsub (Text, " ", "+")
Text=string.gsub(Text,"é","%%%e9")
Text=string.gsub(Text,"è","%%%e8")
Text=string.gsub(Text,"ç","%%%e7")
Text=string.gsub(Text,"ê","%%%ea")
Text=string.gsub(Text,"ô","%%%f4")
Text=string.gsub(Text,"� ","%%%e0")
Text=string.gsub(Text,"â","%%%e2")
Text=string.gsub(Text,"?","%%%3f")
Text=string.gsub(Text,":","%%%3a")
log(Text)
Query=self.Adresse_Unified.."&sn="..self.Mac.."&token="..self.Token.."&tts="..Text.."&ws_acapela="..Voice
--*******Ears position changing****************
--*******Parameters: Left ears, right ears value from 0 to 16
--*******return tru if OK else an error message
function Nabaztag:SetEars(Pos_Gauche,Pos_Droite)
if(Pos_Gauche>16) then
Pos_Gauche=16
if(Pos_Droite>16) then
Pos_Droite=16
Query=self.Adresse_Main.."&sn="..self.Mac.."&token="..self.Token.."&posleft="..Pos_Gauche.."&posright="..Pos_Droite
--*****Reboot rabbit*********
function Nabaztag:Reboot()
return(self:Send_Command(17))
--*********Check if rabbit is connected********
function Nabaztag:Is_Connected()
if(self:Send_Command(15)~=nil) then
if (string.find(self:Send_Command(15),"YES") ~= nil) then
return(true)
return(false)
return(false)
--*********Check if rabbit is sleeping********
function Nabaztag:Is_Sleeping()
if (string.find(self:Send_Command(7),"YES") ~= nil) then
return(true)
return(false)
--*********Check if rabbit can launch an action********
function Nabaztag:Is_Reachable()
return(self:Is_Sleeping() and self:Is_Connected())
function Nabaztag:Status()
if(self:Is_Connected()) then
if(self:Is_Sleeping()) then
return(2)
return(1)
return (0)
and update the code accordingly.
