Threads: 81
as in the subject, I would use a script to pass a string as URL for a frame or image graphic element.
Peppe
Threads: 45
Can you explain what are you trying to achieve in more detail. Probably you need some custom JavaScript code.
Threads: 81
I just would like to change the URL on an event, passing it in a string by a script.
Threads: 81
I am trying to pass the url to an image obect... where am I wrong there?
Threads: 45
Replace image selector with img
Threads: 81
Perfect!
Thank you so much.
Peppe
